Old 02-02-2008, 06:00 AM   #3 (permalink)
Fudog1138
Only if there's sufficient air. Electrical goes inside of a conduit as opposed to relying upon the wires insulation. Though electrical will provide the necessary heat and straw the fuel. The air between tightly packed strawbales is scarce and doesn't burn as well as an "air" mixture would.
So though it will burn, it will take a while to get through it.
If you have an electrical fire, kill the power.
I'm sure you know that, but my Dad is a retired firefighter and I was a volunteer for a while, so I guess I've got that Smokey the Bear thing goin on. Guess all the brainwashing worked huh
