Old 12-15-2008, 01:18 PM   #1 (permalink)
wagonman76
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Another take on the rainy day/mileage improvement theory
Something I was thinking about last night as it poured rain all the way from downstate to home, and I was getting record mileage with the 6000 wagon.
I know that very small changes in the map sensor have a big effect on fuel use. I used a map sensor modifier in the Celeb, and when turning it down just a little, it would cut out when touching the gas. But I did find one spot about 100-150 mv lower than stock where it seemed to give a hint more power under light load. So I left it there. I dont know if it contributes to my mpg gains or not. At the time I didnt notice any better or worse mileage but I was also not hypermiling yet either and I was getting a measly 32 mpg downstate and back consistently. Right now the car is under 2 feet of snow so it wont be experimented with till probably May.
The map sensor is manifold absolute pressure. I was wondering if it might actually measure the differential between manifold vacuum and atmospheric pressure. If so, then I was wondering if changes in atmospheric pressure could throw the map sensor off a bit, possibly in our favor. I believe a barometer measures atmospheric pressure and rain is way on one end of the scale.
Any thoughts?
Winter daily driver, parked most days right now
Summer daily driver
