Old 12-15-2008, 05:56 PM   #41 (permalink)
akashic
TacoModder
akashic's Avatar
rik's prerunner - '03 Tacoma Prerunner Double Cab TRD 4A
90 day: 29.68 mpg (US)
For extensive modifications,it is claimed that a gear change may be necessary to wring out all the MPG from drag reduction.That is a very complicated situation and for a discussion on that I would refer you to Hucho's for a full explanation.
I've seen you mention this before. Did you ever solve this problem on the T-100? I keep wondering when I'll be running into this issue, or if I already am affected by it. I might be slightly less prone, running a Prerunner on a 4cyl. And with the stock lift, I could certainly stand to fit taller tires.
