Yeah, they're called Coffee Urns, ironically. 2 gallons is more than your original coolant system held, so it's probably sufficient.
What are you using to bleed heat from the e-motor you have?
If you're already bleeding heat from there, you could always duct it back through the cabin air filter housing and have semi-free heat, since it's heat that's already being generated.
If you're not bleeding that heat off the motor, maybe a motor cooling system is in order? You could use the circulation of your coffee urn cooling system to help cool the motor too, I would say, and that would add a little extra heat to the coolant, making it warmer for the occupants.
Food for thought.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
