Old 12-15-2008, 10:53 PM   #14 (permalink)
Intrigued
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Intrigue GX
Last 3: 25.94 mpg (US)
Fusible Links... TWO four letter words together...
Originally Posted by wagonman76 View Post
It must have burned some fusible link because it didnt blow any fuse.
OOOOHHHH I Hate fusible links!!! Look just like a regular wire, but when they burn out YOU CAN'T TELL IT!!!
You have to check voltage at the terminal and after the link to tell if the stupid things are burned out or not. We used to pull on them to see if they stretched a lot... which meant the wire inside was burned out...
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
