Old 12-17-2008, 10:47 PM   #15 (permalink)
Intrigued
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Intrigue GX
Last 3: 25.94 mpg (US)
Originally Posted by MPaulHolmes View Post
So, there has to be a copper bus on which all the current flows. Each mosfet will contribute about 8 - 10 amps to the bus. Such a high current requires pretty heavy copper. I'm thinking of using 10 gauge wire for the bus.
So, here's the rub. How do you solder a lead (leed) from a mosfet to such a heavy wire that will be about 6 or 7 inches long? Try it! Take a soldering iron and try it! It's tough.
For cryin' out loud, man! Find a piece of scrap copper tubing somewhere, pound it flat with your Oprah hammer, drill a few holes in it, and BOLT the wires you solder to the leads to the now flat copper strip...or something like that...
...or am I missing something here...
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
