Old 12-18-2008, 10:42 AM   #1 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Instead of vacuum gauge: multimeter on MAP sensor
Just had a thought - probably not original:
Instead of buying a vacuum gauge, another option is to wire a cheap multimeter to the MAP (manifold absolute pressure) sensor (if your car has one).
It wouldn't be too hard to drive a little bit and see what voltage corresponds to the lightest load, then use it as a relative indicator of fuel consumption. Very useful if using the DWL (driving with load) technique.
Maybe make a simple LED array that does the same thing, so you don't have to read numbers.
