You may want to consider using PEX tubing stapled to the underside of the flooring - above the insulation.
And you'll need a Taco pump such as the 007-F5, expansion tank, fill valve, shutoff valves, air separator, thermostat, and I'd probably use Prestone RV antifreeze just in case you leave the house unheated at anytime.
But and the big but here is you need to know how many BTU you will be getting from the wood stove in order to design the system properly and to know if it'll actually produce enough heat to warm the floor.
