Old 12-23-2008, 09:08 AM   #33 (permalink)
MazdaMatt
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
I just had a peak at your schematic and read up on the IXDD414. I would like to HIGHLY recommend that you have some sort of fail-safe switch attached to the enable line instead of tieing it high. You could put it on the dash as the "start" switch.
Also, i don't know if you've done this because i didn't read the code... I would highly recommend that you use a watchdog timer that will put the chip into a reset state where the pwm line is driving the mosfets off.
I'm a computer engineer... i write embedded code for a living and i spend a lot of time dealing with the hardware for which i write code (i've got a pile of boards on my desk right now that i'm testing). I will definately follow your thread and see what you're up to and make little inputs where i can. Be sure to post anything that is puzzling you or any little ideas that you'd like expanded.
Cheers, and good luck.
