bondo, I like your design for the tundra, but it'd look even nicer if you made the side windows for each vehicle go with the door windows on the tundra. the tundra has more square-to-triangle windows and the ones on the cap are more rhombus. if you continued from where the windows end, you could make it flow more naturally with the design of the truck. you'd have better visability, and it make it look more "from the factory"
