Old 12-29-2008, 02:11 PM   #60 (permalink)
rmccomiskie
Ziggy - '95 S6 Sedan
Manfred - '97 A6 Quattro Sedan
90 day: 20.61 mpg (US)
Clarabell - '03 A4 Quattro Avant
Sherman - '98 A6 Quattro Avant
Cab - '96 Cabriolet
Originally Posted by Wingmn View Post
Measured to chasis ground I've got 11.8 V on each pin... All 3. I retouched the solder on pin 2, still 11.8, 11.6, 11.6 on each pin.. When I measure pin 1 and 3 with 2 as my ground I get 0.0...
Once again, the MPGuino still works great under PC power...
I just did the ohm check on the 7805 -
1 2 3
1 8.38 8.78
2 Inf 10.12
3 Inf 5.6
So is my 7805 Bad?
With 12V on the left pin and ground on the middle pin, the right pin should be 5V. Something is definitely not right.
