Thread: My MPGuino Case
Old 12-30-2008, 09:43 PM   #1 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
My MPGuino Case
I figured putting the second mpguino on my dash like before was just asking for trouble till I get my door locks oiled and working so I made a pretty nice enclosure. It is using an old VHS tape box. I just cut one end off, cut a display opening and stuck it in there.
The only problem I had was I didn't know what to do with the buttons. I thought about cutting them off the board but they weren't tall enough to stick through the plastic much. I dug around my junk pile to find some old plastic button caps but ended up using some screws from an old computer case. I just drilled holes over the buttons in the plastic and put the screws in from the back side. They are right up against the buttons and the back of the case keeps the MPGuino from moving. I will probably use something else once I come across something but for now the screws work good and if they didn't have threads they would look fine. The last pic is blurry but you can see how I used the screws.
Now I just need to cover the whole thing with the same fabric the van has and it will look factory. I will probably use the other half the VHS case to make one for my Metro once I get around to ordering another kit.
My Convertible Metro XFI Plug in Hybrid Project build log
