The problem with using a 4 cylinder tach in a 3 cylinder is that the tach reads output from the ignitor and does math.. x/4 = RPM. Lets say x is 4000 on the 4 cylinder, your formula is
4000/4 = 1000 RPM (idle... )
Now, lets assume you put that cluster in your car, and don't change anything about it.
4000/4 = 1000RPM for a four cylinder,
but for the 3 cylinder, the actual formula should be:
4000/3 = 1333.33
So basically, your engine is revving 1330 RPM when your tach is displaying 1000 RPM. The difference won't be linear either... it's a curve.
16000/4 = 4000, 16000/3 = 5333.33.
Now, if you can change caps or resistors to make it do the math correctly, then you're set to go, but just using it without modification will definitely yield an incorrect reading.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
