I am not sure what you are asking for is possible. However, as a solution you may want to look into programmable air vents. Basically the air vent is run on a selonoid which has an independant programmable thermostat. This allows you to control air temps by room independantly by closing or opening specific vents in your house giving you room by room control.
This way if you run your central heat to just one room, it will reach the temp you desire much faster thus using less energy. It's ideal for homes where you need to cool specific areas like the TV room or bedroom at night, without having to keep the entire house at a specific tempertature.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
