Old 01-02-2009, 10:10 PM   #7 (permalink)
Duffman
No not the same results Peter,
Forced Induction gives you variable compression but a fixed expansion ratio. This engine does both. Its the fact that the expansion ratio is larger than the compression ratio in the atkinson cycle that makes it more fuel efficient.
