Old 01-04-2009, 04:26 PM   #33 (permalink)
modmonster
Tracy - '00 corsa
i made a lier box for my MAF sensor today. it worked and was easy to make. it defiantly helped the problems i have with the MAF. i noticed that it wasn't just wide open throttle that open loop that was affected but the whole throttle range. i had to dial it up when i accelerated and down again when i wanted to coast or engine would die. i think the ECU tries to adapt to the new settings each time you change the lie box setting and its confusing. wideband is needed.
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
