Old 01-04-2009, 06:52 PM   #11 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Did you check for cross wiring? I.e. put the ohmeter on lcd 16, and make sure there is no connections where there shouldn't be?
Just for comparison, I did and most of the connections were separated by at least a megaohm, except the following:
LCD pins 1,5,16 all connected.
LCD pins 2 and 3 were seperated by about 10k ohms (shrug).
notes:
unit unplugged
I put ground on LCD 1, then touched positive probe to 2, then 3 ... 16 and noted ohm readings.
Then I put ground on LCD 2, then touched positive probe to 3, then 4 ... 16 and noted ohm readings.
Then I put ground on LCD 3, etc.
