Successful Test at 60 volts!
I rewrote the whole micro-controller program to clean things up a bit. Then I tested the single 100v mosfet controller at 12v, 24v, 36v, 48v, and 60v. It worked perfectly! I set the current limit to 5 amps. When I slowed the wheel down with my hand, you could hear the 4kHz tone get quieter as the current limiting was kicking in and automatically cutting back on the throttle. I would have tested it at 72v, but I ran out of those wire connector things that you can see in the picture, so I couldn't hook up the 6th battery! Oh, that makes me real mad inside!
I'm amazed at how low the amps can be at high voltage to still get excellent performance. It's also amazing that all that power is going through a single mosfet!
I attached the current version of the software, heavily commented.
I was thinking for a kit, buying the stuff in bulk would cut like $50-$100 off the $350 pricetag. I wonder if that will be possible.
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
Reason: Added software attachment
