I can run under 200 kwh/mo excluding my electric heat.
Also, I once had a friend point out to me that it is a bit redundant to say "hot water heater". Ever since then I also find it not redundant so much as just incorrect.
Why would you need an appliance to heat hot water? I use my "water heater" to heat cold water, exclusively.
