Are you sure the LOD value corresponds to absolute
peak theoretical torque output? Or does it mean maximum torque output for a given engine speed? EG: if you floor the gas and hold it there in top gear at 1000 RPM, does it not read LOD=100, and continue to read LOD=100 while the RPM climbs?
EDIT: from the
SGII user manual
LOD = This is a percentage of the maximum power available currently being generated. In some vehicles it is the maximum available at the present RPM.
Seems to be an "it depends" situation.
