Can't help you with the first question too much. Although I'm sure it has a lot to do with monitoring injector pulse width with the engine on a dyno going through all possible scenarios.
Air fuel ratio is not always stoichiometric on a fuel injected car. Newer engines operate almost entirely at stoichiometric air fuel ratios, but not always.
