Old 01-06-2009, 11:17 AM   #109 (permalink)
diesel_john
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
Originally Posted by Cepheuz View Post
i just though of an idea, simple one, but let me know
lets take the fact that my engine is 1289cc (witch would be at WOT)
then the fact that the fuel mix is 13.7:1
that would make the fuel amount @ WOT 94.08cc
and there is only one fuel enrichment and thats the load
so add a volume (the ones in stereos and guitars)dial with a resistor for 6 volt 6volts = 94.08cc
tap into the throttle cable or the throttle to move the volume dial (i'm sorry, i realy don't know the name of it) and ad a contact point the the load enrichment device and do a map for voltage / cc
6volts=94.08cc 3volts=47.04, etc..
add a relay with a resistor and a capasitor to the mix and you can get higher pulse for more acceleration and a pulse for mix increase
could this work?, i might try to do a scematic
Cepheuz, i don't follow your logic entirely but i think you may have just invented what is called a throttle position sensor or TPS.
