Old 01-06-2009, 11:49 AM   #104 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
roflwaffle -
Originally Posted by roflwaffle View Post
If you slap down the throttle at low rpm and LOD goes to ~100, it's based on peak torque. If it increases w/ rpm at WOT, it's based on peak power. If it's based on torque, as long as you have LOD, RPM, and vehicle speed, you can predict fuel consumption.
I tried that last night and it did NOT go to 100. But maybe my RPM wasn't low enough (I was accelerating onto the freeway), so I'll try it again.
Question: What are the units for "Peak Power"? Is there a unit translation/mapping to/from the BSFC chart?
EDIT -
Answer???:
Googled that Power is Kilowatts :
Wiki - Brake specific fuel consumption
http://en.wikipedia.org/wiki/Brake_s...el_consumption
To calculate BSFC, use the formula BSFC = Fuel rate / Power
Where:
Fuel rate is the fuel consumption in grams per hour (g/hr)
Power is the power produced in Kilowatts where kW = w * Tq / 9549.27
w is the engine speed in rpm
Tq is the engine torque in newton meters (N·m)
CarloSW2
American Solar Energy Society
