Old 01-06-2009, 12:01 PM   #105 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
MetroMPG -
Does this only apply to an engine operating in closed loop mode?
I will make sure to display the Open/Closed loop parameter when I repeat the WOT+low RPM test.
This is one of the drawbacks of the ScanGauge, in my understanding. It's relatively accurate provided you stay in closed loop, where it can make calcs based on stoich A/F ratios. But when you get into open loop fuel enrichment at higher loads, it doesn't necessarily know how much more fuel the computer is injecting.
Are you implying that it is using the 02 sensor feedback? From my experience, I do not think it does.
I think it makes calcs based on the assumption of 14.7/1 AFR ratios, but it *derives" it's MPG from all the other data inputs.
CarloSW2
American Solar Energy Society
