Old 01-06-2009, 01:17 PM   #13 (permalink)
Wingmn
Wingmn's Avatar
93 SL2 Auto - '93 SL2
90 day: 34.26 mpg (US)
09 Outlook FWD - '09 Outlook XR
90 day: 21.07 mpg (US)
I think I found the problem.
I desoldered the LCD again in preperation to jumper atmega pins to the LCD pads.
I looked at the back of LCD and noticed Pad 3 had some missing gold on the back side of the pad - here's a picture.
I did some continuity checks between the pads and the little holes directly behind the LCD and there was no continuity between pad 3 and it's corresponding circuit run to it's tiny ring...
On the spiffie schematic pad 3 is labeled as CONTR - it is recieved from the atmega... That would explain why all my continuity checks from the atmega to both sides of the header pin were good, I didn't check the back side of the LCD to their final destination..
What do you guys think?
