Old 01-06-2009, 04:08 PM   #111 (permalink)
roflwaffle
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Originally Posted by cfg83 View Post
roflwaffle -
At around 1100 RPM in 5th gear, I would see as high as 91 LOD. But it wouldn't stay there. As the RPMs ever-so-slowly increased with the MPH, it would fall off. I will do the test again at 1500 RPM, but now I am leaning toward assuming that that it's measuring torque.
CarloSW2
There's no way it's measuring power if you see 91/100 at ~1100rpm/5th. I found an interesting description of LOD as the percent of power (probably meant torque) requested, so I wonder if your load is falling off due to a decrease in VE (volumetric efficiency) w/ speed...
