Old 02-04-2008, 09:29 PM   #5 (permalink)
mattW
Plus in a rear collision you would be in the privileged position of having air bags outside your car! It would good to have one with a semi rigid bottom section that allowed the tail to curl upwards as it deflated into the pick up bed. I'm imagining two hollow tubes on top of each other with a cord or strap through the middle of each of them (sort of like those poles in modern tents). By pulling the top string as the tail deflated you could have it curl up like a monkey's tail rather than sagging down to the ground. Then you might have the possibility of doing while driving as you entered the city and needed a shorter length. I am considering buying an inflatable kiddies pool or large beach ball to carry out some experiments hehehe.
Check out my Green Cars Blog and the DIY electric car Wiki. Enjoy!
