Thread: window film 101
Old 01-09-2009, 04:33 PM   #8 (permalink)
93Cobra#2771
The Green Hornet - '96 Escort Wagon LX
90 day: 39.26 mpg (US)
The Red Rocket - '96 Metro Base
90 day: 53.07 mpg (US)
Originally Posted by captainslug View Post
Assuming you have experience with dissecting the doors in order to remove the glass (requires having the maintenance manual handy), applying tint is fairly easy. You just submerge the glass and tint in soapy water, remove the backing from the tint, apply it to the glass, smooth out the bubbles, and remove the completed piece from the tub to let it dry.
You then trim the excess.
The soapy water retards the adhesive on the tinting film, allowing you to shift it around to remove the air bubbles.
That is a WAY simplified process, and not exactly practical to do for the back window or rear quarter windows, don't you think?
And todays compound curved windows - that method definitely will not work.
No professional tint shops do it that way, and for a reason.
Did you come up with this idea, or have you seen/done it that way before - I'm curious to know?
