Thread: S-10 gears
Old 01-13-2009, 12:11 PM   #2 (permalink)
Intrigued
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Intrigue GX
Last 3: 25.94 mpg (US)
Dad has the 3.73s in his (ZR2). I've seen everything from 3.08s to 4.11s. There may be even a wider range than that.
That must be a fairly tall overdrive 5th, to get 2400 @ 55 with 4.11s. I've seen 1:1 4-speeds with shorter tires running right at 3 grand @ 55...
...not conducive to good fuel mileage!
Here is a place that you could look around and maybe find something...
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
