Old 01-13-2009, 01:22 PM   #6 (permalink)
wriley4409
The gearbox lubes that I am familiar with are:
ATF
motor oil
75w90 gear lube
75w140 gear lube
90w gear lube
You should use whatever type of lubricant that your owners manual calls for, and using pure synthetic lube of the appropriate weight and type will usually result in reduced friction in your transmission.
