Old 01-13-2009, 06:17 PM   #2 (permalink)
captainslug
Misanthropologist
captainslug's Avatar
BORK! - '89 240 DL Wagon
90 day: 21.27 mpg (US)
Sounds more complicated than is needed.
Many E-Bike hub motor kits come with pedal-elec options that will shut the throttle off if the pedals are not moving. You could simply short out the throttle so that any amount of pedaling will trigger the throttle, or build a simple circuit that will alter the throttle (resistance) based on how quickly the pedals are spinning.
