Before you spend money on a Scan Gage, check and make sure your 1994 'Stang is OBDII compatible.
I believe the older Fords were still running EEC4 at that time which is NOT OBDII.
Just a little insight,
Schultz
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
