Old 01-15-2009, 10:00 AM   #15 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Originally Posted by lunarhighway View Post
does anyone know what the wires on the door lock do? i think i'm going to get one that looks rather similar, what are the wires? is that ground and a 12v line for on/off or are their two temporary imputs of on/off?
If you can get it to run off the fan temp switch that would definitely be a much cheaper way to go. However, I'm not sure how you'd go about doing that. The actuator does require a little bit of smarts to drive it properly. Check out post #4 in this thread to see how it works.
