Old 01-15-2009, 02:25 PM   #24 (permalink)
james
Low Roller - '94 Civic VX
90 day: 52.85 mpg (US)
Yep,
the vx is notorious for having large variations in the amount of gas you can get into the tank...which, because of its small tank, makes the MPG calculations vary considerably. All you can do is get FE instrumentation, or take the average from several tanks. I typically see differences of 10 mpg or more per tank. If you get one bad one it could be that the one before was much better and the following one will be better. Just take the avg of several tanks.
