Old 01-15-2009, 07:09 PM   #12 (permalink)
TheSGC
Originally Posted by Christ View Post
Get a set of adjustable coilovers from eBay. The springs are generic cuts, rated just past the OEM rating for spring rates, and you can adjust them up so that even though they're shorter, they will be at standard ride height. They're also less than $60 and the fronts will fit the rears if they wear out.
So those will work? I didn't know if they would cause trouble with my struts, or even be able to cope with the weight.
1996 Civic LX EV
