Old 01-15-2009, 07:38 PM   #900 (permalink)
bennelson
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
Mostly been using 2nd and third gear.
I use 2nd up to 25 mph or so and then 3rd above that.
Here's a video made a while back testing acceleration in a couple different gears - no shifting - just put it in gear and go.
This was pretty much flooring it, meaning I was using all amps I had.
My controller is a 400 amp peak, but my ammeter only goes up to 300, and I've never really had a way to check how much I really can pull out of the controller or not.
For example, there is an adjustment (by screwdriver) in the controller to limit current. I don't even know for sure if that is all the way up or not.
I do know that the ammeter goes up a lot faster in a higher gear while accelerating than in a lower gear.
EDIT: Link won't work right - here's the video directly.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
