Old 01-19-2009, 09:00 AM   #250 (permalink)
MazdaMatt
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
Paul, for surface mount soldering we use solder paste instead of solder wire. It is a syringe filled with a slurry of flux and tiny solder balls. You squirt a tiny drop on each copper pad and place the component down with tweezers. The paste holds it still and you can heat up the pads till the solder balls melt.
