OK. Thanks for the quick reply. I'll go ahead and validate that the fuel flow signal is identical to the injector signal. If it's not, I'll dig into the code to see how it can be interpreted.
As I pursue that approach, am I correct in assuming that the
MPGuino code is looking for a positive going injector signal only? And that a simple method of changing from positive to negative signal is not provided.
