Old 01-20-2009, 05:55 PM   #927 (permalink)
bennelson
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
The charger I am using is a "gentle charger".
These are gel-cell batteries. The insides of them are something like Jello. They need be be charged at a lower voltage than other battery types.
Flooded lead-acid batteries can be charged at a high voltage. They will just convert some of the water/acid into hydrogen and blow it off. You then have to replace it with some distilled water.
The gel-cells are sealed. If you charge them at a high voltage, they can get voids in the Jello and wreck them.
The big advantage to these batteries are that I don't have to worry about them leaking, tipping over, spewing hydrogen gas, etc.
Modern SLAs & AGM batteries have all those same advantages while worrying a lot less about charging voltage. Gel-cells aren't used much any more. In fact, I got such a good deal on them because they were being replaced by AGM batteries in their application.
So, yeah, my batteries are always going to read a little lower because of their style and how they are charged.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
