Old 01-20-2009, 07:26 PM   #4 (permalink)
CobraBall
CobraBall's Avatar
"ATF manufacturers suggest that for every 20˚F increase in operating temperature above 175˚F, the life of the fluid is cut in half. Hence at 195˚F, oil life will be about 50,000 miles. Above 240˚F., it becomes nil."
If you want to monitor the temperature of your transmission fluid, suggest you go to Installing a Transmission Temperature Gauge
