Originally Posted by CobraBall
"ATF manufacturers suggest that for every 20˚F increase in operating temperature above 175˚F, the life of the fluid is cut in half. Hence at 195˚F, oil life will be about 50,000 miles. Above 240˚F., it becomes nil."
If you want to monitor the temperature of your transmission fluid, suggest you go to Installing a Transmission Temperature Gauge
So would the transmission fluid have sort of a 'burt' smell to it if it was overheating ?
( dumb question ? )
Thanks for the link to the transmission sensor.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
