Old 01-21-2009, 09:37 PM   #797 (permalink)
americasfuture2k
americasfuture2k's Avatar
SLOLANE - '08 Aveo5 SV
90 day: 30.55 mpg (US)
yea its for the fiero. i know which injector wires to hook it up to.
were any of those V6's DIS? im sure your two A-bodies would be DIS if they are V6's. and you more than likely have the same ECM. the 1227730. if you do have 6's, look at the ECM plugs. if you see a yellow one and have DIS, then you have the 7730.
remember, i dont have the 2.8 though. i have a 3500 LX9 from a '06 malibu with the OBD I. and some 36# injectors with that walbro 255 fuel pump. major fuel being pushed. so i have a feeling that my uSec/Gal are going to be pretty different. not your typical GM V6 setup of that era.
If you cant fix it with a hammer, then you have an electrical problem
http://www.cardomain.com/ride/3159589
shutup, im working on it
