Try some side skirts to match your front air dam. Won't mess with the looks at all...might match well.
On taller tires if you go skinnier while going slightly taller you are usually better off. Go too tall and you definitely lose. You basically do not want to increase the weight of the tire at all or the width (or the rolling resistance).
