Old 01-22-2009, 11:47 PM   #15 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
I was thinking worst case would be it needs an op amp to drive the input. But really a pull down/voltage divider resistor should work fine. I drove it home with the scope running the whole time and the voltages never changed, so once I get a balance point above/below 2.5V it should be fine long term I figure.
Having to divide the voltage between 14 and 11V should not be that hard though really. The zener can protect the AVR from over voltages and the two resistors as a voltage divider should be all that is needed. I will try out this weekend first with a 100k pot pulldown and a lcd scope I have that will be good enough to see the voltages now that we know what we are looking for.
Code:
                                       R1
                                      ___
                to AVR ---+------+---|___|-- Inj Input
                         | |     z
                      R2 | |     A 5.1V Zener
                         GND    GND
One of these days I will quit making you add stuff to the schematic
My Convertible Metro XFI Plug in Hybrid Project build log
