Old 01-23-2009, 01:57 PM   #4 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Looks like there are different plans. This is most likely yours.
http://www.alabamapower.com/pricing/pdf/fd.pdf
There is a $14.50 charge off the bat for service. Then $.07 per kWh up to 750 kWh. Above that the rate drops to $.058. Thats actually quite cheap.
My guess at the high bill is mainly from heating your apartment. It simply takes tons of energy to heat an area. MetroMPG is currently renting a place and used up 30+ kWh in one day when it was quite cold out, and his place is tiny (and poorly insulated).
