I have a completely stock 1982 honda passport. I weigh 270 lbs. I carry a cobralinks lock (says it weighs 10 pounds, but it feel like 20.. not sure of the weight tho. ) The max weight limit is 300 lbs. If I would loose some weight, i'd probably do better on the mileage. I always get 92 mpg... and ... I always run WOT. I don't try to get good mileage on it, it does it all on it's own.
