Old 11-27-2007, 07:05 PM   #493 (permalink)
MetroMPG
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
DaX suggests a fix for the weak mount:
The rubber in these mounts does tend to dry rot, crack, and fail, causing a loose mount. The cheapest and easiest solution is to go to AutoZone (do they even have those in CA?) or equivalent, and get a product that comes in a caulk tube called 3M Windo Weld:
Excellent tip. Thanks, Dax.
