Old 01-26-2009, 04:28 PM   #46 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
winkosmosis -
Originally Posted by winkosmosis View Post
To cover the antenna spot you can use those plugs they put on faucet holes. Someone on miata.net did that.
BTW, I'd try to put the antenna somewhere that it's not next to metal, because the steel of the body will block the signal from that direction.
That's a good idea, but I'm not sure it would work for the conical antenna spot in my Saturn. I got a black marshmallow shaped "foamy" from Michael's arts and crafts and used that as a plug :
The foamy worked well for me because it was able to compress-to-fit. No UV degradation as far as I can tell.
Another option would be a rubber plug that you can get in the specialty fastener section of hardware stores (I love the specialty fastener section, great place for ideas).
CarloSW2
American Solar Energy Society
