Old 02-06-2008, 01:33 PM   #61 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
That's about what the guy told me when we bought ours. He said the drive motor had just been reconditioned and it alone "would cost thousands" to replace.
That shaft is a little troublesome. Our pump motor had internal splines - plural. has one spline. I know that Jim is going to suggest pressing out the shaft and pressing in a replacement with a proper external end on it.
However... if you're doing a low power conversion, you might be able to get away with using the male shaft stub from your pump and mounting it in a bearing plate.
