Old 01-27-2009, 05:09 PM   #23 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Inducing vacuum in the cylinder before the valve opening event does two things - both of which are undesirable -
1. It makes for more pumping losses (try pulling two cups apart that fit perfectly in each other.)
2. It changes airflow profiles for an otherwise nicely tuned intake system, due to the vacuum caused by the cylinder being part way down with no air movement.. it would cause vacuum pulses in the intake that would ruin both harmonics (check the TB spacer thread) and the overall fluid dynamic profile of the intake itself by increasing the vacuum per intake stroke, in a pulse like fashion.
(#2 is partially speculative, and can't be held as gospel. Please research it before assuming it is correct.)
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
